1999 Pontiac Firebird Coolant leak
1999 PONTIAC FIREBIRD
142,345 MILES • 6 CYL • 2WD • AUTOMATIC
NICNTIC
I have a question i replaced the coolant bypass elbow that goes to the intake manifold & the tensioner assembly because it was leaking and now my car is still leaking in the same area i was told it could be the lower intake manifold gasket.... ? Is this possible ? It would seem that there would be coolant flowing through my engine if that was the case. there isnt coolant and oil mixing but my radiator is also clogged up with brownish crud i was told this is from dexcool coolant. I just want to know if i need to replace my lower intake manifold gasket and what to do about the brown crud in my radiator.... ?
Thank you !
Aug 1, 2009 at 8:24 PM
  • 110,244 POSTS
It could be the gasket. I would recommend getting a dye to put in the coolant and drive the car a few days. THen you take a black light and check to see where the leak is coming from. Also, as far as the radiator, you can try to flush it out or have it rodded out at a radiator shop. If you use dexcool, only use dexcool. Never mix it with other types.
Sep 9, 2009 at 4:55 AM
