1994 Pontiac Firebird Loosing water and don't know where.
JENNY FERRELL
  • 1994 PONTIAC FIREBIRD
Engine Cooling problem
1994 Pontiac Firebird V8 Two Wheel Drive Automatic 172.00 miles
I hope you can help me I had my Radiator replaced in December 08 and my low coolant light started coming on. Now I am having to add around a half gallon of water to my Radiator and nobody can tell where it is going. I have been having trouble also with the car missing. Thank You.
Tuesday, May 12th, 2009 AT 10:16 AM
No leak anywhere could be burning in the combustion chamber-Get the cooling system block and pressure tested.
Tuesday, May 12th, 2009 AT 10:23 AM
THUNDERCAT982
When you replaced your radiator did you also replace the cap? Apparently, the factory caps on late model firebirds and cameros are absolute crap. I had had the same problem with water loss but no apparent leakon my 99 bird, luckily my brother who owned a 99 camero had the exact same porblem and eventually realized that his cap was failing when under pressure. Long story short we both bought new caps from autozone and completely fixed the problem on both cars.
Wednesday, May 27th, 2009 AT 10:56 PM
CDNF-BODYFAN
On the LT1 5.7L V8's, check the water pump. On the lower drivers side of the pump is a weeping hole that will leak when the pump is shot. The important clue is the car 'missing'. The pointy heads at GM, in their infinite wisdom, put the weeping hole directly over the opti-spark distributor and on the '94, this #$&%@*! Thing is not vented to remove moisture. Hopefully this is not your problem as this is a real pain to correct. Good Luck.
Wednesday, June 3rd, 2009 AT 12:27 PM
