1997 Pontiac Firebird leaking form compressor
1997 PONTIAC FIREBIRD
150,560 MILES • 6 CYL • FWD • AUTOMATIC
SUNSHINE.SHINE
when water is poured into the radiator it comes out around the compressor where the belt is
Feb 19, 2010 at 1:23 PM
ERNEST CLARK
  • 1,730 POSTS
The best thing to do is pressurize the system and visually inspect the engine. This will give you a definite place where your leak is coming from.
Yours could be from the water pump, a freeze plug in the head/block, a cracked head/block, etc. There's a few places that water could leak from around your a/c compressor. (But not actually from your compressor)
I'd have to know exactly where this leak is coming from in order to tell you how to fix it.
Write back with this information and I'll help you from there.
Feb 22, 2010 at 1:35 PM
