1995 Pontiac Firebird mis-fire code cyl #6
19,000 MILES • 6 CYL • 2WD • AUTOMATIC
NOT SO LUCKY
Service engine light blinks then goes solid,had code read. The code=cyl 6 mis fire,I've replaced the plug,plug wire,coil module.Trouble still there,engine idles rough,runs but also rough,seems a bit better when warmed up. Would like direct on what to check or replace next? Are the manuals from parts stores in depth enough to provide the path to an answer?
May 12, 2008 at 2:23 PM
MRPACE65
Had the same problem with my 99Firebird more than likely is a spark wiring issue the wire connecting to spark six maybe worn out or dirty try replacing your spark plug wireset and that should resolve the issue
Aug 2, 2008 at 11:57 AM
MRPACE65
Had the same problem with my 99Firebird more than likely is a spark wiring issue the wire connecting to spark six maybe worn out or dirty try replacing your spark plug wireset and that should resolve the issue make sure when you replace the plugs you have the correct firing order otherwise it will continue to idle rough and hesitate
Aug 2, 2008 at 11:59 AM
MERLIN2021
  • 17,250 POSTS
compression test it, and test the injector, see if it is clicking or not.
Aug 2, 2008 at 12:16 PM
SMUDGE10
remove the ignition coils (lable wires) and have them tested. could be a bad coil.
Jul 7, 2009 at 7:59 AM
MERLIN2021
  • 17,250 POSTS
Smudge thanks for the help, but check the date...could have figured it out by now!
Jul 7, 2009 at 9:14 AM
SMUDGE10
ok sorry, so did you?
Jul 8, 2009 at 5:22 AM
MERLIN2021
  • 17,250 POSTS
Assuming he did replace the plug and wire, that leave fuel and compression, I suggested he test the compression, never heard back...
Jul 9, 2009 at 1:22 AM
