I have a 95' P.F.B. with a 3.4l V6. When i got the vehicle it had a miss. It sat for 2 years with old fuel. I pumped it down and replaced with a full tank of 93 octane and a can of Sea Foam. I changed the fuel filter, plugs, wires, and oil filter. No luck with that. I had it scanned and the only code was MAP sensor, changed that, no luck.
The missing only happens under load if you "put your foot in it ", just over normal acceleration. You can "dry rev" it with little hesitation.
Feb 21, 2009 at 11:39 AM
