1995 Pontiac Firebird Heating and cooling system
1995 PONTIAC FIREBIRD
94,000 MILES • V8 • 2WD • MANUAL
ANTONIOAVINAGOMEZ
I replaced the lower radiator hose all the cooling fluids ran out, I replaced the cooling fliuds, but car is over heating and the cooling fans are not coming on.
I do not have the service manual, is there a special procedure to get the fluids filled up?
Thanks,
A needy friend.[img:d2035b6318]http://www.2carpros.com/forum/automotive_pictures/126509_94Firebird_1.jpg[/img:d2035b6318]
Dec 4, 2007 at 4:13 AM
MERLIN2021
  • 17,250 POSTS
After you have filled it and warmed it up, and it circulated and you put the cap on, The next time it's cold check the fluid level on the recovery bottle. Now what happens when you turn on the A/C, does the fan come on? If not try hot wiring it from the battery to check it. If it runs, If not replace fan, if it runs check your email for the testing required!
Dec 4, 2007 at 5:26 AM
