1995 Pontiac Firebird radiator fans don't stop
1995 PONTIAC FIREBIRD
88,900 MILES • V8 • 2WD • AUTOMATIC
CLAUDIO MORALES
After to change water pump & thermostat, blown fuses of air pump, fan actuator then i replaced but when temperature start fan motors don't stops and check engine light is on.
Dec 30, 2007 at 5:01 AM
The check engine light On-pull the code/s to find out what's wrong within the engine management system.
Fan motor continues to run -might be a problem with a temperature switch or fan relay sticking.
Dec 30, 2007 at 5:19 AM
