HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Firebird
Engine
Cylinder Head
Gasket
SPONSORED LINKS
1995 Pontiac Firebird
CHRISTOPHER0617
MEMBER
1995 PONTIAC FIREBIRD
1995 Pontiac Firebird 6 cyl Automatic
My head gasket went. Now ive done most of the work but is there something that I can put in the oil to dilute it from the mud texture that it is?
Wednesday, December 30th, 2009 AT 6:37 PM
JAZEYDEZEY
MEMBER
Run it with oil and a quart of tranny fliud for couple minutes then drain it
SPONSORED LINKS
Sunday, January 3rd, 2010 AT 2:45 AM
Please
login
or
register
to post a reply.
Related Cylinder Head Gasket Content
1970 Pontiac Firebird Cam And Valve Springs
Engine Mechanical Problem 1970 Pontiac Firebird V8 Two Wheel Drive Manual Hi, My Car Is A 1970 Trans Am Ram Air Lll I Had Its...
Asked by
usgeneration
1970
PONTIAC FIREBIRD
VIDEO
Can You Fix a Head Gasket with a Sealer?
Instructional repair video
GUIDE
Cylinder Head Gasket Blown Symptoms
A head gasket failure must be caught early to help protect the engine from additional damage. Understanding and recognizing these symptoms will be beneficial to your ...
1976 Pontiac Firebird 1976 Trans Am, 6.6l (400)
Engine Performance Problem 1976 Pontiac Firebird V8 Two Wheel Drive Automatic What Is The Correct Sequence To Adjust My Rocker Arms...
Asked by
Ohio28
1 ANSWER
1976
PONTIAC FIREBIRD
Electrical Harness 95 Pontiac Firebird 3.4 Liter
My Car Was Parked Do To A Flat And Mouse Ate The Wires Going Into The Harness Between The Air Intake Manifold. I Need To Know What The...
Asked by
chron
4 IMAGES
1995
PONTIAC FIREBIRD
1995 Pontiac Firebird Oil Pan
I Recently Rebuilt My Stock Lt1 350 And Turned It Into A 383 Stroker Motor. When It Was Rebuilt The New Main Studs Did Not Have The Studs...
Asked by
mcgoo700
1 ANSWER
1995
PONTIAC FIREBIRD
Engine Swap Advice
Will Either The 3.8 Twin Turbo From A Nissan Gtr Or The Turbo 3.8 From A Buick Grand National Fit For An Engine Swap In My 2000 Pontiac...
Asked by
Alexander D Ebbing
2000
PONTIAC FIREBIRD
VIEW MORE
SPONSORED LINKS
Coolant Mixing With Engine Oil
Change Oil and Filter Toyota Prius V
Online car repair manuals
