1976 Pontiac Firebird 1976 Trans Am, 6.6L (400)
OHIO28
  • 16 POSTS
Engine Performance problem
1976 Pontiac Firebird V8 Two Wheel Drive Automatic
What is the correct sequence to adjust my rocker arms?
I can't remember and do you have copies of pictures to assist?
Thank you again, you've been a great help.
Ohio28....
Feb 27, 2009 at 11:14 PM
MMPRINCE4000
  • 8,548 POSTS
Easiest way is to remove all plugs, rotate engine to #1 firing position, you can adjust intake and exhaust.
Back off adjusting nut to get a little play, grasp pushrod and CAREFULLY move up and down while tightening adjustment nut, when pushrod will no longer move you are at 0 lash, rotate nut an additional 1 turn (360 degrees) to get preload.
Rotate to next firing position and adjust intake and exhaust. Repeat until all valves are adjusted.
Sorry, could not find pics on a car this old.
Feb 28, 2009 at 1:32 AM
