1995 Pontiac Firebird
KORKEN
  • 1995 PONTIAC FIREBIRD
  • 6 CYL
  • 115,000 MILES
Ok so I just bought a cheap project car and its having some problems that i'm not to sure how to fix. First it makes a sound thats very hard to descibe, somewhat high pitched, when I go faster it gets louder and when I slow down it gets lower, when i'm at a complete stop it doesnt make it at all, I think its something with my rear but not entirely sure. Also i'm 16 and cant drive alone yet so my car kinda just sits in the drive way for now but so the battery doesnt die I go out every night and let it run for a little bit and let it charge up and what not but one night I went to go start it and it woulndn't even crank, the lights flickered and it made a clicking noise.
anyone able to help with this?
Monday, November 2nd, 2009 AT 4:49 PM
FIREBIRDMAN1187
  • 18 POSTS
Ok to the battery the clicking sound and the head lights flickering the battery is dead and to the noise you hear going down the road my 95 firebird done the same thing but my problem was some one put 373 gears in and didnt get the shims right so it made a whinning sound but your problem could be the axle bearings either side or the pinion bearing could be bad
Tuesday, February 2nd, 2010 AT 6:36 PM
KORKEN
Ya I was thinking bearings but wasnt sure, do you know if its safe to drive a car with scratched or damaged bearings like could it damage my rear or?
Tuesday, February 2nd, 2010 AT 10:04 PM
FIREBIRDMAN1187
  • 18 POSTS
Yes it could damage your axles or if its your pinion bearing it will damage the pinion shaft
Thursday, February 4th, 2010 AT 6:54 PM
