I'd want to see what the fuel trims are doing. Check fuel pressure. Check if pressure will hold for a bit, everything off.
Do you have good cylinder compression? There isn't much load on the engine in park or neutral.
SPONSORED LINKS
Monday, September 9th, 2013 AT 11:09 AM
