We replaced the head gasket, everything is put back right, and when we go to start the car all we get is the car cranking (spinning the belts) but nothing else. It'll back fire sometimes, but not too often. We know we have spark, we know there's fuel (maybe too much fuel seeing as the plugs and even o2 sensor are wet to the touch?), we don't know we have compression though. We didn't touch the timming.
Any suggestions on what we should try? And can we do a compression check with accurate readings with a cold engine?
Thanks,
Stuck in Columbus
Thanks,
Stuck in Columbus
Feb 28, 2008 at 11:32 AM
