1994 Pontiac Firebird changing gaskets
1994 PONTIAC FIREBIRD
146,000 MILES • 6 CYL • 2WD • AUTOMATIC
BIGSMOKE
hi i am about to do head gasket change , maybe all engine gaskets , this is my first time doing so do you think it is to complicated for average joe , or can somthing easily be messed up and hard to put back.... like i said i have done only regular maintenance never went that deep into engine . plus do you know any site that might give detailed instructions or schematic....? thanks alot!
May 2, 2009 at 12:53 AM
MERLIN2021
  • 17,250 POSTS
You need a few tools...torque wrench is the most important one, Re setting the timing chain is another biggie, get it wrong and it will not run. Set engine to 1# at Top dead center on compression stroke before you dissasemble it. Also get a manual, this will have tightening sequences and torque values, a must! I dodnt advise this job for a beginner!
May 2, 2009 at 7:13 AM
