1991 Pontiac Firebird starting
KJOHYN1976
  • 1991 PONTIAC FIREBIRD
Electrical problem
1991 Pontiac Firebird V8 Two Wheel Drive Automatic
After I let the firebird sit for extended hours (8-10) it won't start. I have to crawl under it and jump the starter. It will start fine all day until I let it sit again. Any suggestions?
Tuesday, November 3rd, 2009 AT 5:45 PM
JDL
  • 16,098 POSTS
If your saying the starter won't crank when the problem occurs, the purple wire at the starter solenoid should be hot with the key in the start position. If it isn't backtrack the circuit, possible issues, wiring circuit-- neutral switch-- ignition switch, feed to or from--theft system. I can't rule out the starter or solenoid, right now.
Tuesday, November 3rd, 2009 AT 6:30 PM
KJOHYN1976
Will check and get back with you in a day or two. Thank you!
Tuesday, November 3rd, 2009 AT 7:25 PM
