1991 Pontiac Firebird no crank
FIREBIRD1991
  • 1991 PONTIAC FIREBIRD
Engine Mechanical problem
1991 Pontiac Firebird 6 cyl Two Wheel Drive 150000 miles
hi I have a 1991 Pontiac firebird that I replace the steering column on and it wont crank but started befor replaced column. I changed out the key for the original and still nothing and I have power to starter and to the ignition and I cant figure it out
Saturday, January 16th, 2010 AT 9:53 PM
HMAC300
  • 48,601 POSTS
If it wasn't the correct steering column then that is more thatn likely your problem. The wireing is probably different Also if you had the key with the diode in it for security and now you don't that's another problem.
Tuesday, February 2nd, 2010 AT 12:15 PM
