1991 Pontiac Firebird just won, t go
HANKSROY
  • 1991 PONTIAC FIREBIRD
Engine Performance problem
1991 Pontiac Firebird 6 cyl Two Wheel Drive Automatic
i have a 91 firebird it go dead when you try to give it gas. I have put a new fuel pump in and it didn, t change a thing please help. Roy
Wednesday, December 16th, 2009 AT 5:17 PM
ERNEST CLARK
  • 1,730 POSTS
First, is the check engine light on? If so, then that's the place to start. Take your car to AutoZone and have the computer scanned. They'll do this for free.
Next, it's never a good idea to hunt for a problem by replacing parts if you don't know that's the problem. It never works and only costs you money you could've just spent on a mechanic.
Now, when you say "it go dead", do you mean the engine stops or it just doesn't have any power?
I'm assuming you mean it doesn't have any power. This is more than likely an exhaust restriction (converter), or the fuel filter/injectors are clogged.
If you know how to use a pressure gauge, you can check fuel system and exhaust pressure. If you don't, then you'll need to take it to a shop.
Friday, January 22nd, 2010 AT 1:46 PM
