1998 Pontiac Firebird Replaced fuel pump and now my car hes
1998 PONTIAC FIREBIRD
52,000 MILES • V8 • 2WD • AUTOMATIC
KELLEY004
98 Pontiac Trans AM LS1, I ran the car out of gas a few times causing the fuel pump to go bad. I replaced the fuel filter and fuel pump. First problem is the car now takes 2 turns to start up. It will drive ok but I just cant give it to much gas or it will hesitate and bog down. If i floor it the car the just keeps bogging..if i give it gas it just bog and will only run at idle speed.. for about 20 minutes. Also the check engine light came on after i changed the pump, the codes said the MAF and O2 sensors were bad. Ive heard those dont matter and that the fuel pump i bought is just faulty? What do you think?
Mar 23, 2009 at 4:43 AM
Check the fuel pressure/ and the MAF and O2 sensors.
Mar 23, 2009 at 5:31 AM
PISTOLLIANONE
I've had similar problems with other vehicles doing this, it to would bog when accelerating. I put the reader on and found a fault with the MAF. Replaced it and no problem now.
Dec 18, 2009 at 10:10 AM
