Get a test light and start at bbatt pos follow towards junction box then inside to fuse.
Also common problem with Camaro/Firebird go to starter find the battery pos cable. Off of term see two or three smaller red wires. May run up into a metal tube. The wires burn through inside tube will not supply power to ign, fuses Ect.
SPONSORED LINKS
Friday, May 8th, 2009 AT 4:02 PM
