Electrical problem
1986 Pontiac Firebird 6 cyl Two Wheel Drive Automatic
The problem I am having as been on going for some time now. I have replaced Battery and Alternator together so many times, I am going nuts. I have a charging gauge in the dash, which is factory equipment, shows the system at around 13.0. When I turn on the lights, the gauge will drop and not come back up to 13.0, even when idling or driving down the road. As time passes on, the gauge will slowly go down, where I eventually have to start changing Battery and Alternator, then it will return back to 13.0. Could cables going to block or to starter, cause this to happen or am I over looking something all together? Battery and Alternator, when bought, are for this year and motor size of this car. Please help if you can. Thanks..Ozzy
Nov 18, 2008 at 8:29 AM
