1967 Pontiac Firebird V8 Two Wheel Drive Automatic
Does not have spark from coil, (I check while cranking)checked voltage to it and got 10.5 vtz to both side of coil(- and +), (even with the neg. Wire removed?) When cranking. Replaced the coil twice and the same. I checked for lose wires. When key is on I get 12.5 to both sides. Checked continuity on wires to coil to harness plug and to the switch. I tried ohming out the spark plug wires but I couldn't get any beeping on my ohm meter and I tried a couple of wire including the coil wire. What can be happening? Battery is good
Thanks for your help
Victor
SPONSORED LINKS
Friday, August 7th, 2009 AT 11:32 PM
