1985 Pontiac Fiero Dies After Running
JOEBB
I have a 1985 pontiac fiero. Rear wheel drive. 2.8lt. V6. 230,000 km. Auto. The car starts just fine. Will run for about fifteen minutes. then just shuts off. It will start again with a boost. What might this be caused from? I've replaced the distributor Done a basic tune up. Ran a diagnostic, which gave no trouble codes and had a mechanic look at the fuel pump.
Sep 15, 2007 at 11:36 AM
  • 75,988 POSTS
[quote:b7af8aeaf5="joebb"]I have a 1985 pontiac fiero. Rear wheel drive. 2.8lt. V6. 230,000 km. Auto. The car starts just fine. Will run for about fifteen minutes. then just shuts off. What might this be caused from?[/quote:b7af8aeaf5]
Could be an ICM heating up or a failing fuel pump. You need to check for spark to rule out the ignition system. Then we'll go to fuel.
Good Luck
Sep 15, 2007 at 12:01 PM
Suggested Repair
When the engine dies, check for spark to rule out the ignition system, especially an ignition control module that fails as it heats up. If spark is present, test the fuel pump next.
Conversation Summary
The owner of a 1985 Pontiac Fiero 2.8L V6 says it starts and runs about 15 minutes, then shuts off and needs a boost to restart. The distributor was replaced, a basic tune-up was done, diagnostics showed no codes, and a mechanic checked the fuel pump. The expert suggests a heat-related ignition control module or a failing fuel pump and recommends checking spark before investigating fuel.
