1984 Pontiac Fiero getting no gas
1984 PONTIAC FIERO
196,000 MILES • 4 CYL • 2WD • AUTOMATIC
DOMO85
i have a 84 pontiac fiero just installed a brand new fuel pump, filter, and injector for the throttle body and i get no gas from the injector i have gas and pressure all the way to the throttle body but the injector itself isnt doing anything. how do i troubleshoot this type of problem
Jun 10, 2010 at 8:07 AM
If the injector fuses are ok-your problem here if you use a noid lite at the injector harness and it doesn't flash-there's a problem with the computer's ground driver/s for the injector
Jun 10, 2010 at 11:17 AM
