what is the problem if you have no power coming from the wire harness going to the fuel pump relay switch?
Oct 8, 2010 at 4:19 AM
JDL
✓Experienced Mechanic
Check the fuel pump fuse in the fuse box. Any applicable mil codes? Check for power at the fuel pump relay... this vehicle also has a fuel pump cut off wired through the oil pressure switch.
