Engine replacement question
CRAIGE
I'm in the process of doing an engine swap on a 2.2 1995 sunfire with a 2.2 1996 sunfire engine. I'm concerned with a timing related issue regarding the crankshaft positioning cam 1995 Is it important to have the crankshaft positioning cam in the same position as the engine that came out of the car or will the computer in the car acknowledge the position of the cam from the crankshaft positioning sensor?
Nov 25, 2007 at 11:07 AM
MMPRINCE4000
  • 8,548 POSTS
The bigger problem is that you are going from OBD-I to OBD-II. The ECM and probably most of the harness will have to be swapped from the donor car.
Feb 26, 2008 at 10:13 PM
