1993 Pontiac Bonneville Overheating
AUNTJOJO27
I have a 1993 Pontiac Bonneville which is a 3.6L V6 (i believe) I live in Boston and my nephew has this car in Maryland for college, so I cannot be certain of engine size. I have two questions 1. The car runs hot when in stop and go traffic but as soon as it hits the highway with uninteruppted 50+ mph is cools right down what could the problem be - no fluids leaking. 2. Is there a way to find a good, reliable and fair mechanic in Maryland from the internet.
Oct 21, 2007 at 4:21 AM
  • 75,988 POSTS
Sounds like thermostat try this first-if not see below
Coolant temperature sensor,Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Oct 21, 2007 at 8:39 AM
Suggested Repair
Start by replacing or testing the thermostat. If overheating continues, check the coolant temperature sensor, radiator cap pressure, radiator for clogging, fan clutch, electric cooling fan, collapsed hoses, and water pump. The stop-and-go pattern especially points to a cooling fan that is not working at low speed.
Conversation Summary
The owner of a 1993 Pontiac Bonneville reports overheating in stop-and-go traffic that goes away at steady highway speeds, with no fluid leaks. An expert recommends trying the thermostat first, then checking the coolant temperature sensor, radiator cap, radiator, fan clutch, electric fan, hoses, and water pump. A request for help finding a Maryland mechanic was not addressed.
