1997 Pontiac Bonneville High Engine Temp
The dash gauge is about 75% accurate. I recommebnd getting an infra-red digital heat gauge. They are about $65.00 and look like a small pistol. You can point and read temperatures.
A catalytic converter can cause an engine to run hotter. Most garages have an exhaust pressure tester and emissions analyzer to determine if you need to replace it.
If nothing else works my recommendations are to replace the radiator. It costs about $250.00. It is a problem that occurs slowly and you don't see it happen. When you replace the radiator, replace the hose and thermostat.
Good luck!
Suggested Repair
Replace the radiator, hoses, and thermostat if cleaning did not restore normal temperature. Verify the dash gauge with an infrared thermometer, have exhaust backpressure tested for a restricted catalytic converter, and inspect the upper and lower intake manifold gaskets, using the metal-framed lower gasket if they are replaced.
Conversation Summary
A 1997 Pontiac Bonneville SSEi with 142,000 miles runs at 215-218 degrees above 50 mph instead of the previous 195-200 degrees. The owner already had the radiator rodded and cleaned, replaced the thermostat and cap, cleaned the A/C coils, and replaced a failed EGR valve with little temperature change. Experts say a partially clogged radiator is the most likely cause and recommend replacing it with the hoses and thermostat, verifying the gauge with an infrared thermometer, and testing for catalytic-converter restriction. Intake manifold gasket leakage is also suggested as a known issue.
