engine stalls
APETERMAN
Hi my name is Amanda. I have a 1993 Pontiac Bonneville 3.8L with 205,000 miles on it. The car stalls when I'm driving, but it doesn't do it all the time. I was wondering if you could tell me where to find the PCM Relay.
Sep 20, 2007 at 10:37 AM
SERVICE WRITER
  • 9,123 POSTS
Only the SSE shows a relay box, but no relay, fuse 17 is for that. I doubt the relationship for the stalling however to the fuse.
I would think about cleaning the egr, idle control valve and intake valves.
Nov 5, 2018 at 11:11 AM
APETERMAN
I wanted to thank the mechanic who promptly responded to my question. I have had no luck as of yet with this problem. The only thing I have not done as of yet is cleaned the idle control valve. Thanks again so much. I will let you know how it goes.
APETERMAN
I have finally figured out the problem. I changed the Ignition Module and repaired 4 loose wires. My car runs like a dream now. Thank you for everything, and I hope this helps someone else.
