2004 Pontiac Bonneville
FMPOVENZANO
  • 2004 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 68,000 MILES
The winshield wiper only works on the passenger side, the driver side moves a little when turned on but will not wipe. Thank you
Monday, November 30th, 2009 AT 11:42 AM
  • 109,885 POSTS
First, grab the driver's side and see if you can move it by hand with the wipers off. If you can, remove it and inspect the teeth on the inside of the arm. They may be stripped. If they are okay, you need to remove the cowl at the base of the windshield to inspect the wiper linkage. There is a chance something has come apart.
Wednesday, December 16th, 2009 AT 8:09 AM
