a short while after starting the engine the windshield wippers and radio cut out
Apr 22, 2013 at 9:26 AM
HMAC300
CERTIFIED EXPERT
check fuses first as they may have blown then check ground battery to body ground and radio to dash ground
Apr 22, 2013 at 9:32 AM
ENOCKER
MEMBER
when I turn the key the motor will not turn over Ihave no power any where lights ,wippers, windows,gauges, the battery and connections are good .all fuses are good, could this be a relay somewhere or what is my problem.
Apr 22, 2013 at 2:14 PM
HMAC300
CERTIFIED EXPERT
check yoru ign fuse on rh side of dash it's 60 amp itcan also be a bad ignition switch.you can try reseting your security system but that won't cause wipers not to have power.you need to start at battery and see where power stops
