2003 Pontiac Bonneville Brake noise
2003 PONTIAC BONNEVILLE
69,000 MILES • 6 CYL • 2WD • AUTOMATIC
A VAN SLOCHTEREN
I changed the brake pads in the front and the rear.
Soon after the rear brakes started making a (howling noise similar to a bus) when the brakes were applied. Took it to a repair shop, and they suggested that I change the rear pads again. So I upgraded the rear pads. The noise went away, but returned within a week. It is extremely loud and embarrasing.
Sep 6, 2008 at 10:02 AM
KEVIN12881
  • 336 POSTS
I am no mechanic, but perhaps your calipers are bad and are putting pressure on your brakes at all times. Do you have a lack of power? Did you bleed the back lines?
Sep 6, 2008 at 10:27 AM
SUSMAN28888
  • 62 POSTS
You should have replaced rotors with the pads.. have you done rotors? or just pads?
Sep 8, 2008 at 1:27 PM
