2003 Pontiac Bonneville pedal goes to the floor
2003 PONTIAC BONNEVILLE
142,000 MILES • 6 CYL • FWD • AUTOMATIC
BISCIT2375
i change the master cylinder. the power the booster is good. i bleed all four brake lines. still goes to the floor. no warning lights come on. i have tracking control on it.
May 23, 2010 at 6:23 PM
AUTOZONEBRAKESEXPERT
  • 47 POSTS
If it seems to take a long time to stop the car when applying the brakes, where you have to push the pedal down hard to come to a complete stop:
* This condition is often due to ‘brake fade,’ which occurs when the linings become too hot. It may be caused by linings that are too thin or brakes that are overworked.
* This condition may also be caused by air in the hydraulic system, a fluid leak in master cylinder, a hose or line leak in system, and/or if the brakes misadjusted.
* This may also be an indication that the rear (or front) brakes that are not operating as designed. This requires the front brakes to work harder resulting in overheating and longer stopping distances.
Apr 9, 2011 at 1:19 PM
