1992 Pontiac Bonneville soft brakes,left brake pad not rele
CASTLE,ANGELA
Brakes problem
1992 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic
replared rotors,brake pads, calipers,masterclynder when you brake the peddel goes down to floor board brake pad does not release have replaced everything twice and have bleed them four times is there something im over looking? thank you angela
Nov 9, 2009 at 2:28 PM
  • 110,244 POSTS
What do you mean by the "Pad" doesn't release? Also, does it have rear drum or disc brakes? Finally, if the caliper is sticking (pad) check the rubber brake hoses going to the calipers. They may expand when you hit the brakes and be bad internally and not allowing fluid to return to the master cylender. As a result, the caliper stick on.
Dec 16, 2009 at 3:20 AM
