2003 Pontiac Bonneville Alternator
2003 PONTIAC BONNEVILLE
FLETCH09
Electrical problem
2003 Pontiac Bonneville 6 cyl Two Wheel Drive Automatic 116K miles
Is a alternator replacement something that can be done relatively easily by a mechanically inclined person or is it something that should be done by a shop? If so what is the basice procedure, especially the drive belt replacement with proper tension.....
Mar 6, 2010 at 4:09 AM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation . . much appreciated GENERATOR Removal & Installation Disconnect negative battery cable. Remove drive belt. Remove fuel injection sight shield. Remove bolts securing generator brace. Remove generator brace. Disconnect generator harness connector. Reposition protective boot from generator output BAT terminal for access. Remove positive battery cable to generator BAT terminal nut. Disconnect battery positive lead from generator. Remove 3 mounting bolts. Remove generator. To install, reverse removal procedure. Tighten bolts to specification. BELT TENSION NOTE:Drive belt tension is controlled by a belt tensioner. No adjustment is required. Hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_1038.png
Mar 6, 2010 at 9:48 PM
