2002 Pontiac Bonneville car quits running
REDD NOFTZ
  • 2002 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 105,000 MILES
When the car gets warm, it starts to spit and sputter and lose power, and then dies. It then comes back and does it again later. What could be wrong? I put heat and also Sea Foam clean in it.
Sunday, March 21st, 2010 AT 11:00 PM
LEGITIMATE007
  • 5,121 POSTS
I think you have a fuel problem and may have a dirty fuel filter. But fuel pressure needs to be checked to determine if you have a faulty fuel pump or fuel pressure regulator, you may also want to check the fuel pump relay, when it gets hot it may cause an open circuit causing the vehicle to die
Monday, March 22nd, 2010 AT 10:08 PM
LEGITIMATE007
  • 5,121 POSTS
Is there a check engine light on?
Monday, March 22nd, 2010 AT 10:09 PM
REDD NOFTZ
Yes, the check engine light is on. It will start back up after dying.
Tuesday, March 23rd, 2010 AT 9:01 PM
LEGITIMATE007
  • 5,121 POSTS
You know what? We can get right down to the problem if we, can get the computer scanned for fault codes, its usually free depending on what state your in, autozone will do it if you dont live in california, and local parts stores will usually offer the service for free. Have it checked and bring the codes back to me, so we can get the settled once and for all
Tuesday, March 23rd, 2010 AT 9:50 PM
LEGITIMATE007
  • 5,121 POSTS
By the way, thank you for the reputation points you gave me, very much appreciated
jody
Tuesday, March 23rd, 2010 AT 9:51 PM
