2001 Pontiac Bonneville gas tank
2001 PONTIAC BONNEVILLE
104,600 MILES • 6 CYL • FWD • AUTOMATIC
TNDHOUSMAN
when i go to fill up my gas tank it shuts off at 3 gallons and keeps spitting back at me when i try to put fuel in it regardless of how empty it is. it was in a rear end accident a year ago. could it have compromised my tank. also, my car smells of gas after filling it up.
Nov 13, 2009 at 2:05 AM
  • 110,244 POSTS
There is a filler tube that the gas runs through when filling it. Along side of it is a smaller tube that is a vent. When the gas goes into the tank, the air must escape from the vent. Otherwise, it will back up the filler tube and shut the pump. What you need to do is check that vent pipe along the filler tube from under the car. It runs from the top of the filler tube to the tank. Chances are it is damaged, plugged, or partially crushed.
Let me know what you find.
Dec 16, 2009 at 2:48 AM
