[quote:7b579a4fe1="BMRFIXIT"]its under rear of the car by the fuel tank
follow the fuel line.[/quote:7b579a4fe1]
No its actually NOT. It is towards the front of the car, behind the wheelwell "almost" If you are able to locate teh fuel line (it may even be marked with a sticker along it saying "warning fuel, flammable" etc. It is a smallish cylinder. It is mounted to the frame. On my Bonne, it is on the right hand side. And is visible below and beside the engine block.
May 20, 2008 at 6:17 AM
