1994 Pontiac Bonneville Fuel Filter and Injector
1994 PONTIAC BONNEVILLE
210,000 MILES • 6 CYL • FWD • AUTOMATIC
PAUL MAWAKEESIC
  • 9 POSTS
How do you take off fuel filter? need diagram...and how does the fuel injector work? The reason why I'm asking is the car keeps stalling, when I press the gas it goes off..the engine shuts down and I turn it on again then it starts ..seems like the gas is not going through. Can I use something for the fuel injector like oil or something?
Thanks.
May 18, 2010 at 1:17 PM
BLUELIGHTNIN6
  • 16,542 POSTS
it's pretty common for this car to develop a bad crank position sensor. that would definitely be your best bet. It would be a good idea to check your fuel pressure though. If it's a little low, then it might be a good time to replace your fuel pump.
May 18, 2010 at 2:47 PM
