1996 Pontiac Bonneville Sugar in gas tank
MARKJR2389
  • 1996 PONTIAC BONNEVILLE
  • 6 CYL
  • 88,000 MILES
What can I do to save my motor if I discovered sugar in my gas tank and now my car cuts off on me
Friday, November 5th, 2010 AT 12:23 PM
BLUELIGHTNIN6
  • 16,542 POSTS
First of all, don't try starting it again until the mess is cleaned up. You will have to drop the fuel tank and drain and clean it out very well. The fuel filter will also need removed and replaced. Once these are completed, fill half tank with fuel and add a bottle of fuel injector cleaner into the tank as well. Run this through and you may have to replace the new fuel filter afterwards to ensure all the sugar has been pushed through the lines.
Friday, November 5th, 2010 AT 8:09 PM
