2000 Pontiac Bonneville Service Engine Light, Low oil, gas gu
DIABOLIC2448
  • 2000 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 138,500 MILES
Cpl?'S I have, my service engine light is on and the car runs great, also my computer is telling me that my oil level is low which its not, its right right where the oil level should be, I also changed the supercharger oil and that is fine as well. I always check and make sure all my fluids are where they should be. My Last? Is MY gas gauge doesn't work, when I start the car it will go to full and then go right to empty or right after I start driving it. Any Idea's would be very helpful! Thanks
Wednesday, September 15th, 2010 AT 7:35 PM
MMPRINCE4000
  • 8,548 POSTS
Have codes read at most autoparts stores.
The oil level sender probably needs to be changed.
The gas level sender is in tank, since gauge goes to full then empty, gauge is OK, so it is either sender or wiring to it.
Friday, September 17th, 2010 AT 7:08 AM
Related Check Engine Light Content
