2000 Pontiac Bonneville Fuel Delivery
GBURKHARD22
  • 2000 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 109,000 MILES
I have a 2000 Pontiac Bonneville that will start up, run well for 7-10 minutes then stall out and not start back up. If I leave it alone for 35-50 minutes it wil start again but if I try to crank it right away it will barely run and stall again and then just dry crank without starting. Battery dies, etc. There is no check engine light and I have already tried changing out the fuel filter. Seems to run fine while in motion until failure.
Wednesday, September 9th, 2009 AT 10:05 PM
  • 109,913 POSTS
When this happens, have you checked to see if you are getting spark and fuel to the engine? One is most likely missing and I need to know which one.
Wednesday, September 23rd, 2009 AT 10:48 AM
GBURKHARD22
Tried check spark-good and have fuel pressure from pump
Wednesday, September 23rd, 2009 AT 11:50 AM
  • 109,913 POSTS
Is the fuel pressure within spec? Will it start with starting fluid?
Wednesday, September 23rd, 2009 AT 1:20 PM
Related Check Engine Light Content
