2000 Pontiac Bonneville I hit a pot hole
DEBORAH MCKNIGHT
  • 2000 PONTIAC BONNEVILLE
  • V8
  • FWD
  • 114,500 MILES
I hit a sink hole or extra large pot hole. I had to replace the rim and tire they were destroyed. My cars dash lights inside went crazy. Stability system, oil gauge stuck, check gas cap and service engine soon lights came on. Also the speedometer jumped to kilometers. Than my car when I would go above 50 mph would shake. I took it to a body shop where they found numerous suspension things wrong outer tie rod, hubs and bearings. But said that this could not of happened from hitting a pot hole.
Why would my car have all these problems happen right after I hit the pot hole.
Tuesday, April 22nd, 2008 AT 7:10 PM
SUSMAN28888
  • 62 POSTS
You might have had these problems before hand and didnt know about it, or had these problems before hand and hititng that hole just did it over for these parts, these parts are all common parts that need replacing, as for all the gauges, you might have a loose wire or more then lilkly the force of the blow reset the ecm.
Thursday, May 1st, 2008 AT 9:05 PM
Related Check Engine Light Content
