2000 Pontiac Bonneville Noise when turning
75,000 MILES • 6 CYL • FWD • AUTOMATIC
ADON4SURE
  • 5 POSTS
When I am at a stop and turn the wheel all the way to the right it makes a squelling noise. When turned all the way to the left it does not make the noise. I changed the control arms because I thought that would fix the problem. I know I need an alignment but did think that was the reason for the noise. I put transmission fluid in the steering pump when it was low because I did have any stering fluid and a mechanic said that wouldn't hurt anything. Can you all help me?
May 26, 2009 at 11:53 PM
  • 110,248 POSTS
Did you check to make sure the belt is tight enough?
May 29, 2009 at 12:15 AM
ADON4SURE
  • 5 POSTS
I will change the belt and see if that works. Will get back to you.
May 29, 2009 at 2:37 AM
  • 110,248 POSTS
Make sure the belt tensionier is good too.
May 29, 2009 at 3:30 AM
