1999 Pontiac Bonneville Car makes a clicking noise when tur
BONNEVILLE12
  • 13 POSTS
Is there any other way to check and see if the wheel bearing is going bad? I lifted the front end of my car and turned the wheels and it wasn't making the noise. I didn't know if it would still make the noise if it was off the ground or not.
Friday, April 3rd, 2009 AT 12:06 PM
JAMES W.
  • 2,394 POSTS
SOMETIMES, with the wheel off the ground you can shake the tire in and out and detect a little "slop" in a wheel bearing that is starting to wear. BUT, this isn't 100%. I wouldn't want you to rush right out and have a bearing changed that apears a little loose and still have the noise. The choice is yours.
Friday, April 3rd, 2009 AT 12:34 PM
BONNEVILLE12
  • 13 POSTS
Okay! Which changing the wheel bearing, does this affect the alignment at all. My alignment is off and I need to get that fix as soon as possible. I just wanted to know if I should try and get the wheel bearing fixed first or if I should go and get an alignment?
Friday, April 3rd, 2009 AT 12:44 PM
JAMES W.
  • 2,394 POSTS
It "shouldn't" affect the alignment, but if you're going to have a bearing changed, I would do that before the alignment. In addition; in my shop to test for a bad bearing on the front of a GM. We used to lift one wheel at a time and with the engine running in drive, spin the lifted wheel under power. In doing this the wheel will actually twice as fast as it would going down the road. Using this process, we could listen to each side seperately. FOR OBVIOUS REASONS, this has to be done carefully. You don't want to be pulling the car back into the garage after it's gone through the back wall and is sitting in the backyard.
Friday, April 3rd, 2009 AT 2:55 PM
