Would it be correct to say that in the event of high mileage both axles and wheel bearing hubs on both sides need to be refurbished.
two axles and one wheel bearing hub was replaced by the mechanic but the car is not repaired. A bad cv joint is becoming quite an expense.
May 2, 2009 at 7:30 AM
