Im in the process of changing my cv drive axle on the drivers side.I put the new one in and it turns fine until i go to put the hub assembly on.once I get the bolts half way in the axle doesnt want to turn.it gets hung up in three spots on a full rotation.if i loosen the the bolts which takes a little pressure off the axle it turns fine again.
Oct 31, 2008 at 5:24 AM
