1998 Pontiac Bonneville
1998 PONTIAC BONNEVILLE
LEBLANCKESHIA
1998 Pontiac Bonneville 6 cyl
i have a pontiac bonneville se that will crank but wont stay started. as soon as it crank it cut off. i have recently got a new fuel pump thinking it was the problem but its not. i also had my battery charged. is their anything you can help with?
May 29, 2010 at 1:26 PM
Clean out the idle air control valve and EGR valve and test the throttle position sensor
May 29, 2010 at 1:30 PM
LEBLANCKESHIA
is there a possibility that it could be the security system thats on the car causing it not to crank?
May 30, 2010 at 9:34 AM
