My cars Electronic Climate Control (ECC) Unit is reading temperatures at 133*F outside. I replaced the ECC unit and I am getting the same thing again. My car constantly blows hot air when the car is running, when I try to switch the air conditioner on it only comes out of the defrost vents only usually its warm, a clicking and howling noise starts when unit comes on but eventually goes away. I can not get heat or air to blow through the front vents. What could be causing this? Any suggestions?
Apr 14, 2009 at 10:13 AM
