1992 Pontiac Bonneville 6 cyl Two Wheel Drive
my 92 pontiac bonneville recently died while i was driving it then it wouldn't start. i checked to see if there was spark at the coil packs, there wasn't. i took off the coil packs and i have power to the prongs on the ignition module. does this mean that the ignition module is good and i need to check something else or is it possible that ignition module is bad.
Nov 7, 2009 at 6:50 AM
