1990 Pontiac Bonneville wont shift
1990 PONTIAC BONNEVILLE
130,000 MILES • 6 CYL • FWD • AUTOMATIC
FIREMANSAMLEE3
I have a 1990 Pontiac Bonneville with the ever so reliable 3.8 liter V-6. The engine is great but the trans isnt so. When the car sits for several hours and i go to leave in it, the trans wont shift properly. It goes reverse just fine as well as 1st and sometimes 2nd gear, but it will not shift up. This is a big problem for me especially because i make emergency medical and fire responses.
I talked to a dealer who says i should be able to start up and idol for about a minute and go. I changed the filter and gasket, because i was told this is the problem. Guess what it still does the same thing. No it is not leaking, and it is sucking the gas. I was getting almost 20 miles to the gallon in the city before these issues, and about 25 to 30 on the hwy. Now i get a lot less.
Do you think changing the trans control solenoid or the tourque converter clutch lock up solenoid or any other componets help this problem.
Oh, and I also changed the modulator.
Thank you for your time.
Dec 10, 2009 at 10:34 AM
  • 110,244 POSTS
Without a code, everything becomes a guessing game. It could be the control solenoid or a simple shift solenoid. As far as the torque converter lock up, no. It would shift into the gears but not OD.
Has the check engine light ever come on?
Dec 15, 2009 at 11:57 PM
FIREMANSAMLEE3
Yes I have a Check Light.
I put a scanner on and come up with all kinds of codes.
But usually when the car warms up real good the light goes out and the car shifts well.
As I may have said I make emergency responses and need it to run properly. I have no problem letting it warm up for 30 seconds to a minute but having to wait between 5 and 15 minutes isn't feasable . So i have to go out every couple hours while on call and start the car to ensure a prompt response. As you know seconds and minutes count. I also don't have a lot of money like most Americans and have 2 baby girls, so if you all can recommend anything I can do without rebuilding the transmission would be great.
Also if you could tell me were the sensors are located so I can replace them. Thank you For your help.
Dec 16, 2009 at 7:11 PM
