1992 Pontiac Bonneville Sometimes no first or reverse
123,000 MILES • 6 CYL • FWD • AUTOMATIC
FLEA77
This trans was rebuilt a few years ago. Now when I go to put it into gear, most of the time it is fine, sometimes however it will refuse to go into gear (first or reverse). Shifting between L and R a few times seems to get it going, particularly in the morning.
In addition it seems like if I stop a little faster than normal it goes out of gear. Sometimes it will come right back into gear, sometimes I have to move the shifter into L to get it back into gear. Every once in a while this happens when I stop normally.
The rest of the time the trans is fine, shifting properly. I do a lot of highway driving and it seems like the shifts are strong and accurate as they should be. Downshifting on passing is as expected.
Fluid level is good, color is excellent, no weird smells. No check engine lights, and the car is well maintained.
Jan 31, 2009 at 8:17 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like something is sticking in the valve body.When you can move things arouns like that and make it work, it usually involves something sticking.Might want to have a trans shop look at it
Feb 1, 2009 at 12:49 AM
